Recommendations for Lightweight Rear Bumper
SSTJ
Lifetime Supporting Member
SE USA
Unless I can find a way to make my stock rear bumper look better (any suggestions?), I'm interested in replacing it. I have an SE, so I'd like to keep things as light as possible. Other than Savvy, which looks great but expensive, does anyone have any recommendations?
UPDATE: Thanks to some recommendations in the posts below, I'm making this table. Will soon re-arrange in order from lightest to heaviest. Since my main concern is weight, this table won't be helpful to others who are more interested in, say, strength.
  • Love
Reactions: JMT
Wow that plate bumper does look nice.
You could do the same thing with some shackle mounts. you could just have them welded onto the stock bumper with a piece of flat steel reinforcing along the back. cause that stock bumper will like the bend very very easy.
Here is what I'm finding so far:
Brand
Name
Price
Weight
Link
Crown AutoOEM Replacement$7618.5lbshttps://www.quadratec.com/products/12106_56_07.htm
Barnes
Rear Tail Plate Bumper​
$12916lbshttps://www.barnes4wd.com/TJ-LJ-Rear-Tail-Plate-Bumper_p_308.html
Affordable OffroadRear Flush Mount Bumper-JeepYJ/TJ/LJ$15516lbshttps://affordableoffroad.com/shop/rear-flush-mount-bumper-jeepyjtjlj-87-06/
Next VentureTJ/LJ ULTRA HIGH CLEARANCE REAR BUMPER$29923lbshttps://nextventuremotorsports.com/...roducts/tjlj-ultra-high-clearance-rear-bumper
BarnesLow Profile Rear Bumper$30024lbshttps://www.barnes4wd.com/TJ-LJ-YJ-Low-Profile-Rear-Bumper_p_375.html
BarnesLow Profile Rear Bumper With 2" Receiver$32526lbshttps://www.barnes4wd.com/TJ-LJ-YJ-Low-Profile-Rear-Bumper-With-2-Receiver_p_376.html
GenRightTJ/LJ/YJ REAR BUMPER PLATE WITH TOW POINTS$34930lbshttps://genright.com/products/tj-lj-yj-rear-bumper-plate-with-tow-points.html
Fishbone OffroadPiranha Rear Bumper with Step$30531lbshttps://www.fishboneoffroad.com/products/pc/viewPrd.asp?idproduct=126&idcategory=61
Next VentureTJ/LJ/YJ HIGH CLEARANCE HITCH BUMPER$48930–33lbshttps://nextventuremotorsports.com/collections/jeep-wrangler-tj-lj-97-06/products/tj-457
Savvy Off RoadRear Receiver Bumper$59935lbshttps://savvyoffroad.com/product/sav-tjrh/
GenRightTJ/LJ/YJ REAR BUMPER PLATE W/ STEP & TOW POINTS$39935-40lbshttps://genright.com/products/tj-lj-yj-rear-bumper-plate-w-step-tow-points.html
BarnesLow Profile Rear Bumper (Scratch & Dent)$21038lbshttps://www.barnes4wd.com/TJ-LJ-YJ-Low-Profile-Rear-Bumper-Scratch-Dent_p_1366.html
SWAG Offroad"BIG-HIT" TJ-YJ Rear Bumper$329 $47938lbshttps://www.swagoffroad.com/SWAG-BIG-HIT-TJ-YJ-Rear-Bumper-V20_p_91.html
LOD OffroadTJ/LJ Xtreme Duty Rear Bumper$25939lbshttps://lodoffroad.com/products/1996-2006-jeep-tj-lj-xtreme-duty-rear-bumper-2
UCFAluminum Rear Bumper$46741lbshttps://undercoverfab.com/jeep-tj-lj-97-06/201-ucf-aluminum-rear-bumper-for-jeep-yj-tj.html
DirtWorxWrangler and CJ Rear Bumper$27945lbshttps://www.thedirtworx.com/product-page/rear-bumper
Here's my home-made one (in primer). Just flat stock, with holes and tabs.
Ignore the receiver, that only worked because it's an LJ.
Check out the one from Goliath. That's the one I went with and I get tons of complements on it. It wasn't that heavy.
I've got this one from Genright on my YJ SE..along with a MetalCloak aluminum front bumper
here's the pic from the site...mine is an older version that has 4 holes evenly spaced across the back, that they offered clear LED lights for....you're not going to find one much lighter than this kinda' thing (unless someone copies it in aluminum)
I got it because I was going to run the spare tire carrier with it..but changed my mind, went back to 31's, and strapped the spare tire to the floor in the back instead
Reactions: SSTJ
Ok, I made this list. Waiting to hear back from NextVenture and GenRight.
Let me know if I am missing any other lightweight options.
Reactions: inkedrose
I really like my Next Venture rear. The wrapped ends definitely beef it up. I like the lower profile better than the Swag, which I had on my last LJ. And I love that it has safety chain attachment points.
Looking for a lightweight option that still allows towing myself… have a smittybuilt SRC one (without tire carrier) right now…
Reactions: hardtailpan
This is a primary reason I went with a UCF rear bumper. It was light (41lbs), fit my style likes, and could tow. FWIW, it is anchored by 10 bolts. You could do more, but I saw anything more than that as overkill+.
... And I like that one too. I just need to start a GoFundMe page for my new rear bumper.
