Doesn't really matter what kind it was. The point is that stuff happens. Why subject yourself to unnecessary risk? Just unbolt the arms (or whatever is required on your rig) and live to wheel another day.What the. Wonder what kinda compressor he was using.
I hear you. I have heard of those things shooting across the room. Was just wondering if there was a safer one vs the other. Personally I guess I have been lucky and alway make sure both side are clamped even and the safety latch is pushed in all the way.Doesn't really matter what kind it was. The point is that stuff happens. Why subject yourself to unnecessary risk? Just unbolt the arms (or whatever is required on your rig) and live to wheel another day.
That's all well and good, but the Jeep could fall off the jackstands too. It happens.Doesn't really matter what kind it was. The point is that stuff happens. Why subject yourself to unnecessary risk? Just unbolt the arms (or whatever is required on your rig) and live to wheel another day.
Does your opinion apply to the long Currie springs? I ask in order to have proper expectations.Using compressors you don't have to remove the driveshaft or touch the control arms, you are only compressing them a small amount and it is ridiculously easy.
I didn't mean to scare anybody. Stay in your happy place. Really, every post I've reiterated this.Scary stuff for sure, like a time bomb with a surprise timer.
Sure and you could have a stroke while changing the oil. No one is saying things don't happenThat's all well and good, but the Jeep could fall off the jackstands too. It happens.
Yes, and your garage roof COULD cave in on top of you too, right? If you wanna play the "could" game...That's all well and good, but the Jeep could fall off the jackstands too. It happens.
The compression force on the spring is minimal to zero. The jack under the axle close to the hub forces the opposite end to droop out further. The first spring nearly falls out on its own. The second one is removed even easier because there's no spring to compress, it's already out of the way.How is compressing that spring while the Jeep is on jack stands safer than just using the compressors? You got a jack unloading one side of the Jeep on stands then you walk around and stick your hands into the opposite wheel well and pull the spring out, this is safer? This is just like hopping up and down on the hubs, you are doing unsafe stuff because you don't like compressors. It's kinda my whole point.
I'm not sure where you're headed with this, but ok... I'll get to Googling that.Might want to look up the most common cause of injury and death doing automotive repair and factor that into some of the decision making process. You know, risk management.
That's exactly right - and underscores my point. Thank you.Yes, and your garage roof COULD cave in on top of you too, right? If you wanna play the "could" game...
True enough. This isn't the country that won the 2nd world war any more for sure!Sure and you could have a stroke while changing the oil. No one is saying things don't happen
Risk management is to first eliminate a risk. Remaining risks that cannot be eliminated are mitigated.
Jeep on jackstands is a static load. Big difference than a compressed spring getting manhandled.
