After replacing the radiator, the foam that keeps debris from getting in between the radiator and condenser has disintegrated. What have you used to replace that?
More important than you think. Have you seen the crap that gets trapped in the front bottom of the condenser? At least there, you can clean it. Behind it, not so much!I cut some foam pipe insulation for that and the first one fell down in within a couple days. The second try was better and it lasted about a week. That was a couple years ago and I didn't try a third time.
Now I'm wondering how important it is to have that and what am I screwing up driving without it. This thread may stop my wondering about it.
I found this one, which says:I used this 3/4 x 1” high density foam that I got from Amazon.
It has an adhesive strip on one side. Worked very well, and it’s been in there for 3 or 4 years.
I imagine it, or a similar size, would work in the stock setup.
I think one thing that it helps with is pulling air through the condenser rather than through that gap where the foam should be. In theory, being sealed up should make your A/C a little cooler. How much, I don't know. It might not be enough to notice.I actually have my radiator removed to change the water pump. I didn't see anything that fell down between the radiator and the condenser but I'm glad I took that out. While the condenser looked good through the grill, both the condenser and the radiator had the lower three inches blocked with mud baked between the cooling fins. I thought I cleaned all that out with the garden hose but when I checked them with a light on the other side I had to do it again.
I think of it as stacking tolerances. 5% here, 5% here. each one not enough to make any difference, but at some point there is enough loss that it becomes an issue.I think one thing that it helps with is pulling air through the condenser rather than through that gap where the foam should be. In theory, being sealed up should make your A/C a little cooler. How much, I don't know. It might not be enough to notice.
Thanks for this link. I ordered some last night to try out.I used some clip on weather strip, used a Dremel to cut notches around the mounting tabs. Tight, factory look
Here's a link to check it out
https://www.amazon.com/dp/B01AS4FVM4/?tag=wranglerorg-20
beautiful job. looks oem.Thank you for sharing this…
Just replaced my radiator last week and this bulb seal works perfect and looks like it belongs!
I'll admit I like the way that one looks!I put my seal on today too. The one the @kmas0n link. It worked out well.
I used a screwdriver and my shop-vac to clean out the dried up crusty foam.
View attachment 316692View attachment 316693View attachment 316694
