Looking for tips to replace these components myself on a stock 2005 LJ (53,000 miles). Did some research and it seems pretty straightforward (4 arms, 2 bolts each, mind the e-brake cables). Also looks like you can just do this on the ground. But it appears there's one tricky bit: the axle is likely to shift enough to make it difficult to get the second bolt in for each control arm. The two suggestions to address this were:
- Use a ratchet strap to pull it back into place
- Use a "porta-power" ... no idea what this ... to pull/push it back into place
Questions:
- Couldn't you just put a couple of straps on the axle to begin with to keep it from shifting in the first place?
- Any other tips to make sure this goes smoothly? (is thread lock or anti-seize recommended, easier done on jacks with the wheels off, etc.)
Background:
Bad clunk when going from forward<->reverse. The right rear upper control arm bushing is shot, all the rest are cracking, but otherwise fine. Local shop quoted $450 to replace the upper and lower passenger side rear control arms. I'd prefer to do both sides ($900). Found a new set of 4 for less than $100. Though new to vehicle DIY, I've already replaced the shocks, drag link, tie rod and all sway bar end links. Some swearing was involved. I found enough YouTube videos to understand these other repairs pretty well before tackling them. When it comes to stock rear control arms, the resources are sparse and are mostly composed of "how to install adjustable control arms" and only focus on setting the length.
