motomick76
Guest
Yes I'm using the same TB bearing you used. Did you stick with the stock slave and just use the adjustable push rod that came with the adapter? Wasn't sure that rod would work with the stock slave.
No need to change slave, just pull stock rod from boot and install the Novak adjustable one. I have stock slave and Novak push rod that came with the bearing.
