Brian Reynolds
Thanks for the great idea. Now just find a shorter led bulb than I have so it clears the lens.
Sent from my Pixel XL using Tapatalk
ScottB, after seeing your post, I picked up same light. Could you tell exactly where you mounted yours on the hood support bracket, I don't want it to hit anything when hood closes. Thanks!I bought a couple of 1156 replacement LED's from Amazon and neither one worked???? I flipped them both ways and nothing. I could not figure it out, so I got to thinking. The 12volt OEM bulb worked fine but not the LEDs. I discovered that the 12volt bulb would work regardless of of how the wires from the GM light were connected to the Jeeps OEM wiring harness. Positive to positive OR positive to negative. So I simply switched the wires.....................then the LED worked.
Here are some pictures of the output of the LED light. My garage was completely dark.
This mod was well worth the time and the few dollars spent. This should be an put in every vehicle or at least every Jeep or truck.
View attachment 28983 View attachment 28984 View attachment 28985 View attachment 28986 View attachment 28987
Did you notice what model/number your LED replacement bulb is?Thanks for the idea! I found one on eBay with the wiring harness, magnetic base, and an LED bulb. I mounted mine just above the battery to make it easy to reach
View attachment 60478 View attachment 60479
I'd like to know that too. I just ordered that underhood light for myself.Did you notice what model/number your LED replacement bulb is?
Thanks xisophosSo I got the underhood lighting in from eBay along with the bulb I listed in the part above. That bulb is unfortunately too big to fit under the globe of the light itself. The one I went with instead is a 67-CW12-G. Here's a pic with both bulbs and the globe to show the difference.
I then took the one that was too big, and compared it to my reverse lights, and they're pretty much a 1 to 1 swap.
Hope this helps!
Edit: Sorry the pics are bad. I was about to start dinner, and the War Department was starting me down.
No worries!Thanks xisophos
No worries!
The one thing I don't particularly care for is that the smaller bulb, while the diodes are protected by a glass bulb covering, doesn't have as many diodes, so I'm sure it won't put out as much light as the original 1156 that I ordered. I'll probably get another one that has a lot more diodes to keep in the goody bag in case I get into a situation where more light is needed. I like options.![]()
