If they are the OEM sensors, keep them until they give you a reason to replace them.Maybe change out the O2 sensors because people recommend it as preventative maintenance after 80k miles but might wait until a CEL comes up.
I'll be replacing the front fenders and hood. The hood is fine but the PO installed a Poison Spyder hood louver and it offends me. I prefer a more original look. BTW, this is an old pic - the fender rust has progressed to large holes.
Hydro assist
Savvy transmission mount needs flipped
Rockers
Torque box repair
Genright body mounts
Savvy body lift
Tie rod flip
BMB raised sway bar links
I have everything for this minus the hydro assist cylinder. Just need to find the time.
This is the long list of parts I have piled up awaiting installation on my LJ:
Revolution Gear 4.88 Gears with REM Finishing
Barnett Dana 44 Differential Covers
LUX MAX Rock Lights
Custom 7-rocker Switch Panel Above Rearview Mirror
Custom Rocker Switch Panel in Center Dash
Savvy Body and Engine Lifts
Savvy T-case Cable Kit
Hutchinson Rock Monster 15x8 Bead Lock Wheels
RockJock Front Track Bar
RockJock CurrectLync Steering Kit w/ BMB 4340 Tie-rod
Genright Lifted Body Mounts with Rear Lower Rubber Mounts
Cutting and Raising Rear of Frame to Match Body Lift
RockJock Bump Stops
New Dana/Spicer Ball Joints
Artec Racing Quart Crate for Spare Fluids Organization
Currie Mini-skids
Fumoto USA Quick-drain Oil Valve
Air Tank and Coalescing Filter for York OBA System
Poly Performance Shock Towers for Front and Rear Shocks
Fox 2.0 Shocks with DSC Reservoirs (11" front/12" rear)
BMB Shock Reservoir Mounts
Savvy Mid-Arm Lift w/ 4” Lift RockJock Springs
Savvy Gas Tank Skid andSteering Box Skid
Savvy Engine and Transmission Skid
Custom Crossmember and Skid
RCV Front Axles
I still need to purchase these:
35" BFG KM3 Tires
Steering Damper (brand T.B.D.)bought a Rancho (actually, two, so I have a spare) and re-painted it
New Tom Wood Driveshafts
I had hoped to have started this work by now, but I decided to replace the 5.4L engine in my elderly Ford Expedition first so that I have a backup vehicle. I'm elbows-deep in that project right now. Hopefully, I'll start the LJ stuff by Thanksgiving, and I definitely want to be done by early spring next year!
These are just my wants/ideas, so nothing for sure yet:
1. 17” Beadlocks
2. 17” tires
3. Corner armor
4. Genright 0” Boulder’s
5. Touch up frame, bumpers, and sliders
6. Tie Rod Flip (have parts)
7. Frame raise (have parts)
8. Keep learning about suspension geometry
- I have a UCF extra clearance transfer case skid that’s been hanging on my shop wall for months just waiting to be installed.
-Maybe some cheap Amazon rock lights that’s been sitting in the shelf since spring.
There a 50/50 chance I’ll get neither done.
* Downstream O2 sensors (just arrived yesterday, hopefully can avoid replacing cats for a while...)
* Due Again: Rotate tires & spare (just did this morning)
* Replace or repaint door handles and rebuild inside mechanisms (they are spongy and don't always unlock easily...)
* Re-finish fender flares (SEM Satin Black)
* Replace driver side door seal (passenger was replaced last year and solved a TON of small drips inside)
* Research window trim for full doors (the felt lined part the window rides in)
* Maybe upgrade the stereo (factory unit takes about 10 minutes to turn on in the mornings, comes on, cuts out right away until it's warmed up)
* Finally get my rear bumper tie-ins installed so I can tow the quad without worry...(Never on the highway the way it is now, only through town 35mph to the dirt roads)
Wow, I did virtually nothing I wanted to last year.
Maybe this winter?
8 | Savvy T-case cable install | https://wranglertjforum.com/threads/how-to-install-savvy-transfer-case-shifter-kit.63527/ | |
4 | GMRS Install | ||
5 | Tidy Cable for CB | ||
6 | New Speaker install + sub | ||
2 | Oil change | ||
1 | Lube all the CV joints, axles and CAs | ||
11 | Adjust parking brake | ||
Steering Upgrades install | |||
12 | PSC Reservoir | ||
12 | PSC Pump | ||
12 | PSC Cooler | ||
9 | Savvy Engine Skid install | ||
10 | Savvy Gas Skid install | ||
Cage | |||
7 | move seat bar up | ||
13 | install C pillar tie bar | ||
3 | Spare tire carrier install | also fix rear door |
