Snookbend365
I’m in the middle of this right now. The newer year ones will work with the older TJ other than the automatic trans connection. If you order a newer year radiator, and you have an auto trans, my understanding is all you will need is the Hayden 397 part to connect up to the quick disconnect that is in the newer year radiators.
Not 100% sure if some kind of safety arm/clamp is needed to hold the quick disconnect from coming out of the connection port in the radiator (I sent a PM to try to figure this out). My plan is to use my stock tension clamp to connect the flexible hose to the Hayden 397 part
So since I have a manual, I should be alright regardless?
