If you prefer the clamp 4" from the end of the hose, you won't get that with any TJ hoses. The filler neck on the tanks, all of them isn't much more than half that. If you can get the clamp tight on the hose where the hose is on the correct side of the bead, that is firmly on there. Stop being silly.Depends on how far down the hose the bead of the neck is. I prefer the clamp maybe 4" down from the end of the hose so it's firmly on there. It's okay when it scoots off once in a while but when the tank is about ready to be full I like that clamp to stay put. Your mileage may vary though.
