Put the pitchforks back in the barn and settle down.
I’m thinking out loud. I love V8s, straight 6s, flat 4s and other IC engines (except maybe the V6…). But it seems to me there could be some big potential advantages to an electric powertrain in a straight axle 4x4 like a TJ. I don’t mean a hybrid like the 4xe JL even though it apparently has the same torque as the hemi JL. I’m talking about all electric power. Yep, range anxiety is a concern but my TJ with a 19 gallon tank (a hangy downy thing also in the way of a stretch) doesn‘t have great range either.
Electric motors make all of their torque at 0 rpm, are very compact and only need a flexible cable to connect them to their power source. So for crawling to highway driving, shifting gears would really not be necessary. A motor could be mounted at the center of each axle in place of the differential and no driveline upstream of the axle (or gas tank) would be needed. This avoids much of the weight and the huge frictional losses in a traditional set up and simplifies suspension packaging. Battery placement and weight are issues but the elimination of engine, trans, transfer case and driveshafts as well as the modularity of batteries increase options.
There are obviously a bunch of talented builders and drivers on this forum. I’d like to know what you think of the possible pros and cons? My real question is: Could an electric TJ not just work, but actually be a better rock crawler? We are starting to see electric UTVs like the Polaris Ranger EV. Are you aware of anyone in the off-road community that has built something similar, maybe an e-buggy?
