SlimCrawler is the nickname for Matson’s dick. The meaning behind BD Suspensions was better.All that thing will do is peel if it is used for what it is implied to be used for.
I modified a Barnes plate pretty heavily...I don't like how the Barnes leaves an open bottom edge either, but it least has tabs for the lower bolts and would at least be easy to weld a strip of 3/16" to. Probably add some to the backside of where that tab is attached as well.
https://wranglertjforum.com/threads/custom-high-clearance-bumpers.48723/post-840953
Yeah, I hit the tank skid then, if it's a sharp enough drop, the hitch receiver. My original design had the cross member wrapped, but once I looked at it, I decided it wasn't necessary.Nice! The end extensions are perfect for what I was picturing. I'll have an easier time modifying the logo, too... My last name starts with an S so it'll just take a little cutting.
I like the rotobroach and plug weld idea too. I was thinking of grinding out a groove around the back side of the shackle tab but I like your move better. Plus it gives me an excuse to get a rotobroach setup.
The only thing I might do different is to add another strip to box in the bottom edge across the middle so it wraps under the crossmember and doesn't have the flat edge to get stuck on. But I have an LJ without a back end tuck so mine is gonna be much more prone to contact than yours.
I have to. If I want to use the hub kit, I have to go back to the 760x joint.So you are ditching the big u joint shafts?
You will love the added caster though.I have to. If I want to use the hub kit, I have to go back to the 763x joint.
That's a big reason for why I want to do this, even if I'm giving up some strength.You will love the added caster though.
Why do you want more caster? I don’t have any experience with caster changes in 4 wheeled vehicles. But, in the the case of mountain bikes, a slacker head tube angle (I think that should be like increasing caster?) will make the steering feel less snappy or less nervous which can be good or bad depending on the situation.That's a big reason for why I want to do this, even if I'm giving to some strength.
I figured that is why. I’ve always run a little more caster than you’d normally get with our driveline angle, but I wish I had put it to 7* sooner. So much more pleasant on the street.That's a big reason for why I want to do this, even if I'm giving to some strength.
Low caster makes the steering way more wandery. It takes way less work to keep the Jeep going straight down the road with 7* of caster (stock amount).Why do you want more caster? I don’t have any experience with caster changes in 4 wheeled vehicles. But, in the the case of mountain bikes, a slacker head tube angle (I think that should be like increasing caster?) will make the steering feel less snappy or less nervous which can be good or bad depending on the situation.
Same reason as any other vehicle. More caster will calm down the steering. I currently have as much as I can get without front driveshaft vibes. By removing the shaft from the equation during normal driving, I can add more.Why do you want more caster? I don’t have any experience with caster changes in 4 wheeled vehicles. But, in the the case of mountain bikes, a slacker head tube angle (I think that should be like increasing caster?) will make the steering feel less snappy or less nervous which can be good or bad depending on the situation.
The hub kit also uses early rotors which stick out .22” more than the late rotors.To make the Warn small hub kit work with the upcoming switch to 17" wheels, I ended up using the JK Moabs I bought several years ago. This is the math on the JK wheels.
6" JK Wheel Backspacing
-.875" Hub kit
5.125" BS
-1.25" Adapter spacer
3.875" Final Front Backspacing
-2" Adapter spacer
4" Final Rear Backspacing
So, I'll be pulling the wheels in a bit from my current 3.75" backspacing.
Thx. Sounds similar to mountain bikes. For a downhill bike, at speed, the slacker head tube angle makes it more stable.Low caster makes the steering way more wandery. It takes way less work to keep the Jeep going straight down the road with 7* of caster (stock amount).
By track bike do you mean a fixie with a 75deg head tube? Sounds fun, ish in the right place. But then so does a 62 degree head tube on a trail so steep you can’t walk itTrack bikes vs touring bikes have very significant differences in head tube angles, too. Agility vs stability.
