Okay thank you I will try it. Maybe tonight probably tomorrowIf an inch solves the problem, then do it.
Which arms are those? And do you have both uppers and lowers?Okay thank you I will try it. Maybe tonight probably tomorrow
Lowers and yesWhich arms are those? And do you have both uppers and lowers?
What brand? Savvy lowers are shorter than most for this reason.Lowers and yes
Lowers move the axle and uppers tilt the pinion for the most part right?
Core4x4What brand?
Both uppers and lowers move the axle and rotate the pinion. You can't change one without affecting the other.
There is a walkthrough thread in the how to section. When I do it, I start at ride height, guess at the front/back, set the pinion, bring the axle up to fully compressed shocks to check clearances and reposition the front/back to come back to ride height to fix the pinion, repeat until good. It takes a few rounds to get there.Core4x4
And yeahh but to move the axle forward I move it where I want it, set the lowers, then adjust uppers to get the pinion where I want it right? So much stuff to do in the right order lol
It can a little but I already pushed it as far back as it'll go today. The track bar is hitting the bolt itself unfortunately so I think moving the axle is my best betCan the GTS move a little? There's slots on the front holes, but I don't remember with the back ones and can't run look at mine, which might buy you 1/4-1/2" too.
Yes!
When lifting from the diff it hits the edge of the skid which I could probably trim but lifting from driver side tire (which is probably more realistic to happen off-road) it hits the bolt and nut
AngledView attachment 321892
I'm not exactly sure how that bolt is mounted into the crossmember. I'll try to look at it closer tomorrow, that is a good idea too. Although I think it'd probably still hit it eventually... this happens with ~3" of exposed shock shaft left on driver side so it's really in the way where the axle is right nowIf you turned the bolt around so that the head of the bolt was facing the skid would it it clear then? And maybe use a button head bolt?
What would you use to bend the track bar?I know I had a hard crash with my JKS rear trackbar, angled bracket, and Savvy skid. If moving the axle doesn't get it, Bend the track bar, trim the flange, or move the mounting point.
20 ton pressWhat would you use to bend the track bar?
Oof okay don't have one of those. Hopefully I can move the axle forward enough... It looks like I should be able to pull it forward enough to just need to trim the flange possibly, hoping it will angle away from the cross member from there I'm not sure how much I want to trim that20 ton press
You know people that do, so let me know if it becomes necessary.Oof okay don't have one of those. Hopefully I can move the axle forward enough... It looks like I should be able to pull it forward enough to just need to trim the flange possibly, hoping it will angle away from the cross member from there I'm not sure how much I want to trim that
Thank you!You know people that do, so let me know if it becomes necessary.
Wow good work! I really hope it doesn't come to that lol that is way beyond my skill and equipment level. That's the JKS track bar?Here is what I was workin with...
and my solution...because I didn't have a press either...
I've since had to modify this. This picture only shows the bracket tacked in. When I fully welded it, the OEM bracket where the trackbar used to mount is pretty thin and it tore. I basically had to rebuild the whole mount and I used pieces and parts of the JKS angled bracket and a Currie Reinforcement bracket that goes to the axle...
I ended up with plenty of clearance though
CorrectThank you!
