Help with the SwayLOC
Plumber1
Tito's, Tacos and Trails
San Ramon, CA
I am currently running the Currie A/R and looking to up grade to the Swayloc. I like air actuated version but not sure it will work with my current setup. When I turn my wheels all the way it looks like should be no clearance problems. But if you look at my A/R you can where the tires rub at full articulation and full turn. So I am concerned that the air actuator will get knocked off.
I would like to hear from anyone that is running the air version.
Thanks
Paging Dr. @Wildman…
Did he stretch the front? Link length, tire size, axle width, backspacing, steering limits and shock travel also affect where and if the tire contacts the sway bar.
Thanks
Your tire will rub. Looks like ORO knows it, too. Based on the rounded edges on the reciever piece the locking pin shoots into.
Reactions: lBasket and Irun
Do you really need the air actuated version? It takes few seconds to flip the lever . you can do it when you are airing your tires down. It's less expensive and less parts to install/maintain. I have it in my Jeep (went from stock to Swayloc directly) and it's been great.
No I don’t but since I already have OBA why not
I have/had the SwayLoc and air cylinder on mine because with the AiRock it's integrated into the system and unlocks when I selected off-road mode.
I never had rubbing issues but my front axle isn't stock so I can't help there. I did this on one trip but never figured out why.
https://app.photobucket.com/u/wildman4x4nut/a/338c9cf3-7d85-4c29-bea4-9a8968bd1e79/p/708634ac-9a82-40c6-91af-6694d30e7bf2]
[/URL]
https://app.photobucket.com/u/wildman4x4nut/a/338c9cf3-7d85-4c29-bea4-9a8968bd1e79/p/24fa4f34-b6ee-4016-bab8-98620bb0c347]
[/URL]
I've got one I'm going to be selling at some point. PM me if you want the info on it.
  • Wow
Reactions: Irun
Just going by your current configured setup, and the fact your tires are already rubbing that much. A SwayLoc will make even more contact with your tire almost certainly…
Edited for accuracy…
The air cylinder is farther behind where you would rub at so that isn't a concern. The latch mechanism would be where you might rub. If you watch this video you can see that the tire wouldn't come close to the air cylinder. And these are 38" TSL SX tires. You still might hit the arm but that would be it.
Reactions: Irun
He seems to be hitting everywhere between these lines. That’s why I made the statement I did. I could easily be wrong though…
I see what you mean about the air cylinder…
Your arms were pointed up pretty high back then.
The air actuated SwayLOC would only make some sense if you had a CTIS and never had to leave the cab. If you have to get out to air down, it takes two seconds to flip the SwayLOC lever. Put the money saved towards fuel. 😆
I also don’t see a reason for the air activated. It could not be easier to simply flip the unlock/lock switch. You don’t even have to be on level ground.
Reactions: L J and psrivats
  • Backspace: 3.63
My wheels with 3.75” backspacing and 33x12.50” tires just kisses the manual SwayLoc’s sliding mechanism from what I consider normal street driving. Haven’t had the SwayLoc off-road as of yet but I’m not overly worried about it…
