How to remove flexplate mounting bolts
H_E_H
California
How do I remove this six bolts on the flexplate. I have a second person up front, holding the engine from turning as I attempt to loosen the bolts, but I'm having no luck.
Should I spray a lubricant a few days before attempting to loosen them? Thanks for any insight.
Sometimes a quick strong pull on a long breaker bar will get them going too. Yeah screwdriver, but it needs to be a big one so you don’t snap it off. (Or at least a decent quality one)
Reactions: H_E_H
Dude get yourself a frigging impact..harbor freight and Walmart even carry them now. Im not saying go buy one right now but definitely put it on your Christmas list
I don't even own an air compressor. Just a growing collection of the basic tools. I'll consider it though!
And if you don’t have an impact, wedge a screwdriver in the teeth to hold it in place
I'm not understanding this approach. I wedge the screwdriver in the teeth of the flexplate, but what is the screwdriver propped against to keep it from moving? Thanks
Shove a long screwdriver through a torque converter bolt hole to wedge the flex plate against the engine block.
I feel so spoiled from power tools after seeing this post, I zap them on and off all the time. Brap!!
The battery powered are what I use, and I have a large compressor and all the air tools. The Craftsman V20 battery impact does everything I need
  • Wow
Reactions: H_E_H
Thanks for the pic.,
Dude. If there are battery-powered can do it, I may just make that purchase. Thanks
Reactions: TJ Jim
Harbor Freight Tools has a few inexpensive battery powered impact wrenches. They're too inexpensive to not acquire one and they're decent quality. I have one of their Bauer battery powered drills and it has been surprisingly good over several years now.
This is a 1/2" but they have 3/8" too which likely would be enough for bolt sizes like those. https://www.harborfreight.com/20v-cordless-12-in-impact-wrench-tool-only-63629.html Personally I use inexpensive air tools but a proper air compressor is not cheap.
I have tried that, but the screwdriver was up against the side of the oil pan...? and had absolutely no leverage. I'll try again. Thanks
Thanks, Jerry! Yeah, Most of my stuff is 3/8", so that's good to know. I'll probably make a trip to HF today. Thank you!
Reactions: Jerry Bransford
Pneumatic tools are so yesterday...like Jerry said go to harbor freight and buy an impact gun they are a game changer
Reactions: Ticks
