Overall I like my front from them, but it did require mods to make it what it should have been for a modified rig. Deeper deck and no laser cutout M.
In the world of steel stubby bumpers they really are pretty good. And we made ours a lot better.
I took a closer look at this one and will say the same things I said about the other one.
Uptravel definitely was not a priority with that design.
I haven't dug into it, but the previous design, folks were getting 6 inches up in the front with the motobilt 4 link kit.
Edit: while using the motobilt front half frame swap which is a no brainer for more up travel and packaging.
No defending motobilt blindly. Just appreciate deeper conversation and discussions about it without guessing or speculating, which seems to be the case for this thread.
We don't need a front half frame kit to get 6" up on a 4" spring lift.
Nor recognize the massive hangy downy bits.
In your opinion, what’s the limit for short arms in regards to tire size?
Unless you dont mind the stock drop or drive a Jk/JL with their massive hangy downy bits off the rear axle.
Well, we are on a TJ forum so I'll assume we don't want the latter. The shovel is a travesty of the original design.
I will agree with that.
Makes me wonder how much can be sucked in if doing a v8 swap, with a trans and transfercase to support it without cutting into the tub.
All the while supporting a bigger tire and wanting more than 190hp at the crank
Me tooMakes me wonder how much can be sucked in if doing a v8 swap, with a trans and transfercase to support it without cutting into the tub.
And lots of beating
For sure. I just think people want to seem like they're doing a bunch to make something work when much might be unnecessary, even detrimental, with a well thought out build. The frame kits from MB seem to be far into that end of the spectrum. The front half kits don't even support an AR or SL, intentionally, which more than makes them useless in my book.
I’m strongly considering a few slices in the tj floor to level the atlas and weld in some filler panels. But not there yet.
Cutting and patching the floor is not bad. For me, the challenge there was modifying the drivers side fold and tumble seat bracket to clear the tucked Atlas, while still keeping it functional.
But, ya gots ta do it….
I figured I’d confer with you on it when I get closer.
