Are you bragging that your drill matches your grille?
He's just showing his bad taste in power tools.
Ouch!
Nah, he’s doing a number 2 on his Jeep.
How do you guys like the hard top storage solution I ended up coming up with?
What are those things standing behind the hardtop?
Get some 4x4's to set the top on. When I had my daughters hard top stored on the ground like that and we had some really heavy winds it cracked the top on one side by the rear window. I think having it sitting on 4x4's would allow the wind to go under it and not cause it to crack as easy.
But I could be wrong here too.
I'd add flat ground without the top flexing or preloaded. My top wanted to sit off to the drivers side when i put it on last winter. It sagged downhill in the summer heat
I do need to prop up the downhill side eventually so that I can finally repair damage from my managerial work anyways. Thanks!
