Blown front axle u-joint
What does blown mean? Just noisy? Or broken into pieces and it is going to tear apart a ball joint?
Removing the drive shaft does nothing to stop an axle shaft from spinning with the front wheels.
Do you need to move the Jeep a few feet or to a different town?
I have a dis axle ujoint and need to move the rubi to where I can replace the
You can't drive it like that. You can either remove the inner axle shaft so you can drive it or have it put on a flat bed truck. If you remove the inner shaft so you can drive it make sure to leave the outer stub shaft installed as that's what holds the unit bearing hub together.
Retainer broke and one cap felll out of joint. I found it when I connected sway bar. I have ordered axle assembly. I need to move it about 50 miles. Would a dolly be ok with front wheels raised?
One more piece of information... it's unlikely just the u-joint broke on its own. Odds are one of the ears on the inner or outer axle shaft that hold the u-joints stretched or broke with released the u-joint so it could spin and break. I'd replace both the inner shaft and outer stub shaft along with installing a fresh Spicer 5-760x u-joint which is direct fit stronger and more durable replacement for the standard Spicer 297 u-joint the factory installed.
And yes it'd be fine to take it home with the front-end up on a dolly. Shift the transfer case to Neutral before starting home.
Just pull the shaft out with the unit bearing and separate the inner from the outer. Then reinstall the outer shaft together with the unit bearing. The unit bearing requires the outer shaft bolted to it in order to keep it from breaking in half. You can drive back and forth across the entire country that way.
Dont forget the copious amounts of trash to keep the gear oil in the tube.
Reactions: JMT and jjvw
In my 2006 owner's manual it says this:
Front or rear wheel lifts should not be used. Internal damage to the transmission or transfer case will occur if a front or rear wheel lift is used when recreational towing.
Andy
Reactions: gatertamer
We need to stop doing this. How many folks run hub kits?
Who is "we", what is "this" and where does the OP mention hub kits?
If your response is based on my lack of knowledge, then here is what is @Chris wrote on the About page for the forum:
One thing that really bothers me with so many other forums is the general feeling of hostility you encounter as a new member. Go to almost any other forum and post a frequently asked question, and you'll typically be met with replies such as "Learn how to use the search feature!", and other rude remarks.
If your response is not based on my lack of knowledge then I would appreciate if you could elaborate on what the issue is with what is written in the owner's manual. Thanks! :D
Andy
  • Face Palm
Reactions: psrivats
Andy
The large number of front hub conversions in use show that the owner's manual is completely full of shit in this regard. A point and topic that is debated, corrected and then argued about every single time a front axle issue shows up where someone wants to use a tow dolly. See if you can guess how much I care about what Chris wrote?
X2 to Blaine's comment which is illustrated by the common use of aftermarket manual hubs. Unlocked manual hubs, as I have, mean the front axle shafts are not turning while driving which is exactly what happens when the front wheels are up on a dolly.
Which is why we have realized for years the owner's manual advice to not use a tow-dolly might have been correct at some point in Jeep's history but it's certainly not correct for the TJ.
Reactions: AndyA
I hope it's okay.
I have disconnected my front driveshaft (to reduce vibes) on several cross-country trips.
I hope it's okay.
So far, so good with my hub kit.
The forums have been telling lots of people to drive around without a front or rear driveshaft for various good reasons for decades. We don't see transfer cases blowing up very often.
