not yet. no.
Could save you from chopping up the lower perch any more for a quick and cheap bolt on. I got em from Savvys website, also on Curries site (rockjock 4x4)
not yet. no.
Have you done the shock relocation brackets? Like $53
I'm drawing a blank right now, but aren't there some downsides to the relocation brackets?
Those are Ranchos and cannot be flipped. The OP will need different shocks.
I think the biggest downside is the additional leverage whatever obstacle you smash into has on the mounts, bending the factory bracket. I forgot about this option, flip the shocks upside down. Free 99
Those look the same as I installed 21+ years ago, only to remove them within a month or two because they kept getting hung up on the trail because they hang lower than the OE brackets.
FIFY.@Shawn at Tom Wood's said it great with all the right reasons.
>4” driveline lift SSSYE
≤ 4” driveline lift SYE
I'd trim the spring perch, not many shocks work as well when flipped.Personally I'll be buying a shock that I can flip or trim the perch or a combination.
Just cut the lower spring seat for free.
spring perches are cut. this winter the shock mount will have to be removed and relocated.
Is that at full droop?
Mine gets really close to my brake line.
that’s sitting flat on the floor.
