That’s done.Should raise the body mounts first.
You may have seen this before, but I think Blaine's solution is elegant. Adel clamps is what they're called.
Yes, those are Adel clamps, and that’s essentially my plan.
Locker switch mounted. There’s enough room for another bank if I decide to swap the front PowerTrax Locker for an Eaton E-Locker.
@LJonloan as will be running wires during transmission swap should consider this? Don’t have raised body mounts but body lift gives room maybe?
@LJonloan could we do something like this for the OD switch as don’t have normal location in center console anymore?
Yes MrBlaine already shared advice to splice those wires. Already have Savvy tuck and mid-arm is a dream item so might as well do it. I picked up these but will admit at least partially was from seeing Robby Layton plug them on his YouTube channel so not sure they are right things for this job. https://solderstick.com/products/so...der-wire-connector-kit?variant=37378635923622
You may have to get another switch panel bezel if you don’t have room for the OD switch because the factory switches click into a part that’s built into the switch panel. The OD switch only fits in the second bank from the right due to a slot on the side of the bank that fits a ridge on the switch. Unless someone knows something I don’t know.
File/dremel the ridge off. I think I had to do that with one of the XJ switch bodies that I put an aftermarket OEM style rocker on. I did that Frankenstein switch so the print on the rocker would light up like the OEM ones do.
P.s. it’s not necessary to move the lines on top of the rail. I did so because they have always been in the way of my Savvy MUA crossmember braces and it will help prep for a future midarm if I go that direction.
You’ll have 4-wires going from the TCase back to the fuel pump (to the fuel pump connector). There’s no reason to drop the tank to replace it with the new harness. Just splice into them at the rail. Make sure and stagger the cuts at least as much as a butt connector length so they will all fit tidy within the loom.
Blaine told me about non-insulated butt connectors covered with adhesive lined shrink wrap to make connections. Using Klein wire crimpers/strippers they work fantastic.
https://www.sherco-auto.com/non-insulated-terminals.html
https://www.amazon.com/dp/B084GDLSCK?tag=wranglerorg-20
Forged Wire Strippers Wire Stripper/Cutter/Crimper, 10-18 Awg Stranded https://www.lowes.com/pd/Klein-Tool...-Cutter-Crimper-10-18-Awg-Stranded/5014305451
I think he still needs a stock bank to use the stock OD switch due to how they click in on top and bottom. But yes, filing that ridge off would enable him to use another bank.
If he needs more stock banks I think there’s a 97-02 option with 6 banks (3 on left + 3 on right).
