Nashville TJ's Build - Continued
Besides, no time for the rig with Christmas coming. With two new grandkids this year I have a couple of toy boxes to make. On top of these for a couple of doggies in the family:
I do have the carving on one of the kids’ toy boxes complete. Caleb’s brother already has a Jeep, so this is Pop Pop’s other hobby:
You're expected to be there even if it has to stay on the trailer.
That would be an expensive trip to Moab to just sit... And I'm not a very good passenger...
Not that simple at all on my rig. You’ll remember I built this thing specifically for 40’s, and it uses every bit of clearance - especially at the back of the front inner fenders. Even if it was just a matter of lowering the bump stops, even that’s a big job with my pneumatic bump setup. Beyond that, I really need tomswap front axles to make the jump. But, I have thought about just slapping on the 42’s and see what happens, but my practical mind usually wins out…
Part of it is that I’ve now cut four sidewalls on these Razrs - including at Moab back in June - and I no longer have confidence in them. Treps would it have that problem.
WOW I didn't know that you had cut that many sidewalls... Shame on BFG for discontinuing your tire...
You could always go (EEK) TSL since a lot of their tires have some tough sidewalls...
Yes I know for you lift it to fit a taller tire is really a lot of work. And I know how hard you worked for that tire to fender clearance in the front. And if you went to 42's then would you have to be thinking about a stronger front axle to match your rear???
Believe me I get it. If I want to even consider 40's I've got to first get stronger axles. And then I'm not sure. But heck I want to just drive it for a while first.
Man you're AWESOME... Those are great.
The front axle is plenty strong for 42’s or 43’s, that’s not the issue. I run spacers in the front to match the width of the 14 bolt, and the spacers actually create a clearance issue at the back of the fender at full lock. I need to go to a wider axle to deal with that.
Thanks brother.
I guess I'd misunderstood.. So still need a new axle just isn't a strength issue..
So we both need wider axles... I'd like to think I can squeak by with 65" WMS since I'd like to try and keep my width down to fit between those pesky trees that grow up here in the PNW...
Reactions: reddvltj
And my next project for after Christmas. Another big rolling steel work bench with 400 pound capacity drawers. No time for Jeep stuff… 😉
I’ve ordered the drawer units which slide down inside the frame. They should be here just before Christmas. Mainly though, just another fun project to occupy my time.
Not an option, Soldier!
Well I hadn't planned on missing this years but a cracked block sort of screwed shit up...
View attachment 575463View attachment 575464
That is very cool...
Reactions: reddvltj
Happy Thanksgiving, Dudes. Hope you all have a great one.
We have 5 grandchildren under 4 with us here this morning. It’s crazy!
Happy Thanksgiving to you & yours also. My daughter is working & then going to spend the afternoon at a event with friends so I'm Home Alone....
So I'm working on my Jeep.
