Woodworkin' and mechanicin' - love it!
I would love to have a metal lathe, as making these plugs out of aluminum would have been cool. It's on the list after the Bridgeport...
The long side - passenger - shaft was out of true about 15 thou in the center. The short side - driver - shaft (the side on which the carrier bearing spun) was out 8 thou. I don't know what the specs are on these things, but that seems close enough. Is this a reasonable level of straight?
I was thinking the same (not that my thoughts on the subject are worth anything, but its nice when I have a thought identical to the more experienced folksI would think that would be okay, but I have no personal engineering experience with live axles to base that opinion on. I would think that the splines being a loose fit gives some allowance for runout.
Jeff, looking through your build thread, it looks like you built that axle about four years ago. Since you're an old feller like me,is it possible you heated that bearing and dropped it on instead of pressing it on? If so, it's possible that the journal was slightly too small and you didn't notice it. I'm baffled as to how the inner race spun if it was an adequate press-fit.
Edited to answer my own question: I went a bit more forward in this thread, and there are pics of you pressing the carrier bearings on. {scratches head}
I'm 38.
Me, too! (in spirit, anyway)
The shims finally came in last night, and I did spend a little time getting the pinion dialed in. First up, I mic'd and marked the rest of the pinion preload shims:
The first setup at 88 thou locked the pinion bearing, indicated not nearly enough shim. So to bracket the results, I moved up to 101 thou.
This is the pinion bearing stack. The sleeve sits on the bearing, and the shims sit on the sleeve.
The pinion housing drops down onto the inner bearing, the outer bearing drops in, and finally the yoke and nut. The outer bearing is a press fit and is drawn down with the pinion nut using an impact. The yoke tool helps a lot here:
The final torque on the pinion nut is 250 foot pounds. Even with this long torque wrench, it takes some effort.
Finally, you test the pinion bearing preload using an inch pound dial torque wrench. On the 14 bolt, the pinion bearing preload target range is 20 - 35 inch pounds. At 88 thou of shims, the bearing bound. Now at 101 thou, the bearing preload was 0, but at least I had the bracket.
Then you start again. Back to the press to press out the pinion from the bearing and housing, change the shim stack and start again...
I took me 8 rounds to get where I wanted to be. Here is the path:
When you get close, small changes in the shim stack results in big changes in preload. When I hit 35 inch pounds at 92 thou, I was at the top of the range, and did not want to be that close. Adding just 1 thou to the shim stack dropped the preload to 15 - below the range. I went back down to 92 thou and hit 40. WTH? But when I pulled it apart, I double checked the stack and it was actually 92 thou - hence my change in the notes...
Finally went back up to 92, but this time I used a different combination of shims to get to 92, and the mic showed a total stack of just a few tenths less than 92, which gave me 34 preload. That looked like the best I was going to get, so I called it good.
The final step is to tap in the pinion seal, install the yoke, torque down a new pinion locking nut, and the pinion is complete.
Now, it's finally pattern time...
I recently learned how to do this with my HP30. Also very finicky in the 0.001 or less range to get rotational toque spot on. In that case I got the pinion depth dialed in before using any pre-load shims. Here, its the reverse because your depth is controlled by shims under that 6 bolt flange, correct? Pretty cool set up in that you can do it on your bench.
When you are bracketing, do you walk up to full pinion nut torque slowly to prevent damaging the bears?
Did you use set up bearings or keep pressing on and off the finals?
