Needs more yellow
Why stainless? I want to say non-stainless steel hardware typically performs better if corrosion isn't the driving factor.
Jeff - are you sure the problem wasn't that the bolt loosened, and then broke? One problem with flat-head cap screws is that if the countersink you're installing it into is slightly off-axis, you get a concentrated load. Those concentrated loads result in crazy-high localized stress that will cold-work the bracket, making the hole slightly larger, which allows slight movement, and then that movement causes impact damage that opens the hole up even larger. And then it's a self-perpetuating loosening until you lose all clamp load. A few good hits once that happens, and the screw breaks.
Moving to a larger screw usually won't solve that type of failure, unless you go to a grossly larger screw that can handle the impact loads, but that's not a good solution because you don't want things moving, right? I'd recommend putting those screws on your pre-ride check list, and paint some hash marks on them to see if they are coming loose. If you keep tightening them, they'll eventually "seat in" to a point where there's no more cold-working and they'll stay tight (usually). Don't assume that the larger screws will alleviate the problem. My money is on the loosening being the root cause.
Also, the reason you didn't find flat-head cap screws in Grade 8 is because that standard, called the SAE J429 standard, doesn't cover cap screws. Cap screws (socket-head, button-head, and flat-head, primarily) are a different beast altogether and are covered under the ASME B18.3 standard. The tensile strength for standard alloy steel flat-head cap screws up to 1/2" diameter is 145,000 psi, which is almost as high as the SAE J429 standard of 150,000 psi, so they are practically of equal strength. The problem with standard alloy steel cap screws (of any head type) is that they are very hard to find in anything other than black oxide finish, which has horrible corrosion problems (they'll rust after the first time they get wet). The alloys used for cap screws is susceptible to hydrogen embrittlement (hydrogen atoms getting into the atomic structure of the steel during the plating process), so you can't find them anywhere with zinc plating. As you pointed out, there are other specialized alloys out there, but they are expensive.
Anyway, keep up the awesome work, my friend!
Hell, this one lasted 15 years…
So I had the same thing happen to my front mounting bolts which resulted in the same issue. On mine, it was from the tank taking hits. I upgraded the bolts and then it eventually cracked the flange and ripped the bolt out of the flange. I had to weld on new front mounts which picked up the cross-member (not the frame) on my TJ. Eventually I just relocated the tank.
Jeff,
They are talking about ECGS 14 bolt axles and towards @ 5:48 of the video ECGS is talking about the shaved 14 bolt and how the shaved gear is for buddies since it doesn't oil as well or shed heat as well. Video linked to the picture.
buggies not buddies.
| Temperature | Voltage adjustment for 12V system | Target absorption voltage |
| -20°C (-4°F) | +1.08V | 15.48V |
| -10°C (14°F) | +0.72V | 15.12V |
| 0°C (32°F) | +0.48V | 14.88V |
| 10°C (50°F) | +0.36V | 14.76V |
| 20°C (68°F) | +0.12V | 14.52V |
| 25°C (77°F) | 0.0V | 14.4V |
| 30°C (86°F) | -0.12V | 14.28V |
| 40°C (104°F) | -0.36V | 14.04V |
| 50°C (122°F) | -0.60V | 13.80V |
So I thought it would be a fun project for an afternoon. I broke out my HP Tuners setup, and went to work:
When I updated the charging table, I had to modify my actual values just a tiny bit for the PCM to accept. Here are the actual charging voltages that the PCM would accept:
I thought I would be smart and actually test the results. So, prior to making the change, I fired up the HP Tuners data logger and ran a log. Voltage is tracked under "Control Module Voltage:"
Then I made the changes to the table, and ran another log. Feeling pretty good about my technical abilities at this point I exported both the before and after log data and dumped the detail into a spread sheet. I then averaged the before and after voltages, and here they are:
Stock Charging Table: 14.089 volts
New Charging Table: 14.097 volts
So yeah, my change did in fact increase the voltage: by 8 thousandths of a volt....
Well, crap. It took me just a few seconds to realize what was going on. I run a Premier Power Welder on the rig, and guess what - it has its own 14-volt regulator.
Nothing like wasting an afternoon.....
