Basket's Build
I think your drag link is pushed in/flattened on the bend where the tie rod mounts.
If it’s only rubbing on one side you could adjust your track bar a little bit but the axle shifts to the passenger side as the axle cycles upward so that’s not that abnormal. Other than the brake line, the rest of the rubbing wouldn’t concern me.
I actually don't know how those are contacting?? This is full stuff at full lock. There's like an inch of clearance
Also is this contact normal??
An inch of clearance until you push hard on the tire against a rock and pull the steering linkage over a little more . Are your stop bolts on the axle knuckle adjusted correctly ?
Wheels with a decent back spacing will help with that.
Reactions: reddvltj
I have never touched them
I do have 1.5" spacers already
Reactions: reddvltj
Yeah it only seems to do it when the wheel is cranked all the way to the driver side. Would that be making the track bar shorter to shift the axle driver side a little bit?
Reactions: reddvltj
Any reinforcement necessary? I don't know how to gauge if its strong enough for when I land on the engine skid
An expert in metallurgy by no mean so, take this for what it's worth. If you go the route of clearancing the skid support, as long as you don't get wild and only clearance it just enough that the yoke isn't hitting it, the integrity isn't going to be reduced much if any more than what the damage has already caused.
On the other hand if @Abendage said turns out to be the issue then adding some bump stop is the better option...
Reactions: lBasket
Crank the steering wheel all the way to when it stops turning , ratchet strap the steering wheel tight so it can't move then go out and look at the stop bolt/linkage interface. Do it in both directions. You can even adjust the bolt to bottom out a little sooner to help keep the tire out of contacting things.
Almost symmetrical!
