It's a filter cap. You can just unplug to see if it makes a difference.
Did you download the FSM?
Did you ever run it with just the cam sensor connected?
Unplug the crank sensor connector. Long crank, it will run on the cam sensor only.
Have you done a compression test yet?
3 and 4 fire at the same time, from the same coil.
Same circuit for both. Both fire every time they are at TDC. One on compression, one on exh.
More likely fuel injector. Check the injectors resistance. They should all be 12 to 15 ohms or so.
I'll say you are persistent, I would of done filled it with Tannerite and blew it up
HOPEFULLY FINAL UPDATE:
Threw in new NGK Coil Rail...
Runs better than the day I got her. No more tractor idle, now more surging, and not a single CEL returned. Drove it 5 miles to get gas. Crazy a bad coil could create all this, but happy it was as simple as that.
New coil rail also ended up being my fix for a major cylinder 3 misfire and what seemed like clogged cats. Took 4 months of diagnosing, coil rail testing good 2 or 3 times, a compression test, fuel pressure test, and lots of other various straw grabbing before I just caved and bought a coil rail off amazon (so I could return it if it wasn't the fix I needed) just to try it. Lo and behold, trouble free driving ever since.
