Does anyone know for sure if the big bolt pattern Yukon hub kit uses the outer axel stub from a CJ? Part numbers look to be the same and from what I have found most parts in the kit are interchangeable with the CJ stuff.
I’m putting together an oh $&*t collection of parts for a Colorado trip coming up. Looking up the part numbers in the Yukon manual last night the axel shafts they list are the same part number for their replacement Cj shafts. I’m going to call them when I get a chance but I’m going with they most likely are Cj shafts. I know the inner bearing kit for the shaft is.
I do know that the old school way to convert a Dana 30 to use locking hubs was to cannibalize CJ parts. So it would make sense if it does in fact use a CJ outer.I’m putting together an oh $&*t collection of parts for a Colorado trip coming up. Looking up the part numbers in the Yukon manual last night the axel shafts they list are the same part number for their replacement Cj shafts. I’m going to call them when I get a chance but I’m going with they most likely are Cj shafts. I know the inner bearing kit for the shaft is.
How do you get them to fit the knuckle?I do know that the old school way to convert a Dana 30 to use locking hubs was to cannibalize CJ parts. So it would make sense if it does in fact use a CJ outer.
Nice, what trails? I'm off of i70 by Vail if you need anything over this way.I’m putting together an oh $&*t collection of parts for a Colorado trip coming up.
[/QUOT
Haven’t really decided yet, we want to keep it fairly simple. My wife is deathly afraid of heights so Black Bear is off the list, she seen some videos and threatened serious bodily harm if I took her on that. We are staying just outside of Ouray for about 12 days.
They dont exist anymore...which was on another posting that blaine was investigating.Reid Racing's Chevy'a Dana 44 outer knuckles bolt onto early style Dana 30 inner C's (inner knuckles) and allow the use of chevy and aftermarket outer parts to include locking hubs.
*Note* To run this outer knuckle you will need to find early style inner knuckles (C's) to weld onto your TJ Dana 30, or your swapped XJ bolt in high pinion Dana 30.
https://reidracing.biz/products/chevy-heavy-duty-flat-top-dana-44-knuckles/
wrong...They dont exist anymore...which was on another posting that blaine was investigating.
