I too recently replaced the lights in my garage with LED. Such an amazing difference!Not really Jeep related but I started on my garage lighting project. I need to repair the ceiling before I mount the last two lights. I've posted this in the off topic thread. I had a lot of help on this, thanks to Shawn for putting up with all my questions, texts and calls.
Before:
View attachment 76822View attachment 76823
After with Prime Lights 5700 lumen LEDs.
Literally night and day!I too recently replaced the lights in my garage with LED. Such an amazing difference!
What was the backspacing on your old 10" wheels?
Awesome so you gained a little with the new wheels.3-11/16". Or 3.68"
Where did you buy the hand throttle at? Also do you have any change in cable tension depending on which gear you're in and the relation of the shifter to the front of the body? (2nd is further than 1st from the engine)
Oh I'm sure if it was changing the tension on the cable you would hear an rpm change as it applies more or less tension on the throttle. Let me know if it takes off in 2nd gear.
