Ask @GarzaDoes 4 Low Parts have any discount codes going on now???
Isn't it only 1"? And iirc their snubber extensions are horrible.
Rokmen makes a nice aluminum pucked BL. Just saying.
Very interesting! only $109 but just 1" not 1.25" . Not a deal breaker though!
https://www.rokmen.com/rokmen-1-body-lift.html
I can't quite tell from the pic, but it looks like 13 machined spacers. This suggests they might be doing the grill snubbers the way we like it done.
They screw up into the grill with the flat head bolt and require the retaining tab on the OEM snubber to be cut off. So you need to use glue or something to keep the snubber in the extension.
Ah. The glue part is kind of dumb.
Yup. Especially considering that both faces are flat and smooth so there's not any mechanical grip. Plus, those parts move around offroad so I can't imagine they'd survive long before loosing one.
... Since Savvy is out for you, most TT's on the market won't require as much clearance to the tub as the Savvy system.
Funny how that is. Another example where it comes into play is the GR body mount kit where the goal is to remove most of the very same body lift pucks you paid good money for.
You're gonna lose that precious 1/4" with that GR kit.
https://genright.com/products/body-mount-lift-kit-tj-lj.html
Those snubbers aren't coming out of there.
The word from someone close and also uses those is that the description is wrong. They are designed for 1.25".
I've personally held these. I couldn't find a way that they wouldn't fall out?
Could you still use the Savvy skid system with these? I wonder about the crossmember.This is correct. They are 1.25". I have them on my red LJ and plan to do the same on the khaki TJ.
