I'm getting new wheels when I go to 35 inch tires so should I go up to a 16 inch wheel or stay at a 15 inch wheel
I could be thinking of someone else, but weren't you running 24x12" wheels for a while?15s or 17s.
16s trend toward 3/4 ton and 1 ton pickups.
Definitely somebody else. @billiebob likely has the skinniest wheels/tires on the forumI could be thinking of someone else, but weren't you running 24x12" wheels for a while?
My dry humor fails again. Lol!Definitely somebody else. @billiebob likely has the skinniest wheels/tires on the forum
Considering it would be ungodly to ever run 24x12s on a TJ it should've been obvious but I really wasn't sureMy dry humor fails again. Lol!
2 incheswhat's the difference between 15x8 and 15x10
Unless you're planning on running a tire width over 12.5 I wouldn't go with a 10+ width wheel.what's the difference between 15x8 and 15x10
Technically yes. Though if you're not planning to replace at least the front axle with something longer and extending the wheelbase for something that big you won't like the long-term results. 37's are a little too big for a TJ with the factory axles. And there's no good way to make the front axle strong enough for 37's, especially if your TJ is a daily driver. Not with stronger axle shafts, tubing the axles, trusses, etc. since its biggest unfixable problem preventing the long-term successful running of 37's is its ball joint size. And there are no stronger ball joints available for it. If there was I'd probably be running 37's by now.Will 37’a fit a 6” short arm suspension lift?
Depends on how you are going to use the Jeep. If it is a rock crawler, then I would follow the advice of the crawlers on this forum and go with their 15” recommendation for maximum sidewall when airing down. If you are just building a very callable trail rig then go 17”, which opens up your brake and tire options in the future. I wouldn’t go 16” in any case because of the likelihood of limited tire options in the future, even though I think they are perfect from an aesthetic perspective.
