oil change with Stahlbus valve installation
View attachment 135423View attachment 135424View attachment 135425
Replaced crown OPDA and new Mopar sensor with a NOS Mopar OPDA with sg mod and Mopar original sensor today. No more codes!
We used to have a beautiful girl named Eisha, one of my best. Really miss her.Beautiful shepherd, great markings.
Someone had made a kit to modify the factory OPDA awhile back before crown and dorman made their OPDA.What's the "sg mod" that you mention?
We lost our Shepherd/Chow mix in 2015, her name was Tipper. She is 12 years old in the picture. I just remembered she got run over by a Wrangler when she was a year old. The tires didn’t hit her but she rolled under it, she got cut up real bad and knocked out a couple teeth. I was at work and my MIL was watching her, she saw a squirrel and took off!We used to have a beautiful girl named Eisha, one of my best. Really miss her.View attachment 135482
Been meaning to do this for awhile now. What material do you use to make it?Made my own version on the Jeep Instatrunk….made the top longer to slide under the rear seatbelt mounts. Only way to get the shelf out now is to lower the back seat and slide it towards the front. So with the rear door locked its pretty secure. Very simple and will stop some undesirables trying to get their mits on my stuff.
View attachment 135569View attachment 135570
Nothing fancy....just some 15mm (sorry half inch) treated pine....if you lean on it it will flex a little so I put 2 cross beams underneath for support....it does the job and I can still take it out quickly by folding the back seat up and dropping in my tool box for work.Been meaning to do this for awhile now. What material do you use to make it?
Big difference in the looks of that front end! I like itPut on some Trucklite knock-off's I got from a forum member on and installed some tube fenders I found on CL:
Thanks dude. I feel like it looks even better from more of a distance.Big difference in the looks of that front end! I like it
Looks great!Thanks dude. I feel like it looks even better from more of a distance.
Today I finished up what I ran out of daylight on yesterday. The factory subwoofer box between the seats has been previously upgraded to the Kicker 6.5 & the Kicker 200.1 Amp. On certain bass frequencies, the tray that holds junk in the center console would rattle. My solution, cover it in sound deadening material. I also put some on the inside of the center console on the passenger side (away from the direction of the sub speaker.) The result is a much tighter base, with less rattling noises.
View attachment 135596View attachment 135598View attachment 135597
