Here we go down the rabbit hole
Where's the end of this damn tunnel?Oh, he's already down it. He's just digging deeper!
I can do that, not too invasive. ThanksYou'll have to re drill a new hole for the bottom bolt, I think.
You know I had to try on the 35’s. They’re 35x13.5r15, crazy wide.
This is a little bit of an experiment. My wife loved the big tires. I’m not convinced. The tires are sticking out so far, but I see why the backspacing on the 15x10 rims are 4”, to keep them out of the CA’s. I will probably stick with 33’sHow long until you go to the Currie 4" for clearance?
I wondered how long it would take you.
Only one day and I had to put them on.I drove it up to 50mph. Tires need balancing.
Back on 33's. I think this is where I was meant to be. TT next. That's my build goal.
Those 13.5 wide tires looked a bit big.Back on 33's. I think this is where I was meant to be. TT next. That's my build goal.
Those 13.5 wide tires looked INSANE!
The 10" wide wheels weren't helping either I would guess.Fixed it!
It’s a Currie bracket on the bottom they say to weld it. For as many bolts as that has I’m not sure that would be mandatory.Drove over to ID today and picked up (6) 15x10 wheels with (6) 35x13.5r15. It doesn’t get much better than this. However, not sure these will see the Jeep anytime soon.
They are much bigger than 33s
Angled rear trackbar bracket came in from @Kris M . It appears to be brand new! Very kind of you! I hope the mounting simply replaces the old relocation bracket.
Hmm...yeah, I just read the install instructions, last step is to weld the two tabs to the axle tube. Seems you could run it for awhile till you happen to run into a welder.It’s a Currie bracket on the bottom they say to weld it. For as many bolts as that has I’m not sure that would be mandatory.
