Hog turned me on to the Home Depot foil coat self adhesive duct insulation for heat and noise...it is light , won’t absorb water , easy to cut and reposition , and has body so you can slide vertically in places like behind the fan motor under the dash . It’s only 22.00 per roll.
I have done the front of B3 , my intrepid 06 Rubicon and am making a removable rubber floor system from Sams Club rubber cargo mat material , flexible and about 15 square feet is 20 bucks .
Installed seat risers , bought 1.5” and had em sliced so one set did 2 tj’s
tightened the valve cover .
repaired the cable inside the backseat with a bike cable and aluminum cable crimp on end
Had the front shaft balanced in my 03, Whitey the Rubicon ...it is absolutely car like in drive quality now ...maybe not a real nice car ...but definitely great . Never underestimate shaft and joint condition . Learned a lesson here.
