xxdabroxx
I think you would be better off going with parts designed for the TJ, but thats just my opinion. I'm sure people have made them work, I don't know what is involved though.
Okay, I've got some more questions for you fine gentlemen.
I don't know enough about suspension (my only knowledge coming from drop springs on small import cars and adjusting coilovers/etc on the same types of cars) to accurately diagnose what's needed as a bandaid fix until I finish putting this frankenlift together.
The problem: The front of my TJ sags.. I'm 6'4" and about 290 pounds and if I sit down on the front bumper it takes the front suspension down to the bump stops. Is this a shock, a spring or both kind of issue? The whole jeep sways like a drunk Marine if I take turns too hard or make hard corrections while driving/etc (Not dangerously far sways, mind you, but it feels more like driving a late 90s Grand Marquis than it does a 2006 Wrangler).
One of the local guys is going to pass me his OEM XJ front shocks and, if they're in better shape than mine, I'm thinking about mounting them but if not I'm trying to figure out what I need to do to stiffen up/raise the suspension a bit or if I should just wait until I've got the new springs/shocks/trackbar ordered to do anything.
I can speak to that. JK front springs aren't even as tall as TJ front springs. You'll lose height. I tried that with JKU Rubicon front springs. No good. The rear springs, on the other hand...Had another local guy offer me his stock JK Springs/Shocks with the added caveat that they would require a bit of work to mount and stand about 3" taller than the stock TJ setup. Is that a viable setup? (I'd still need tires/wheels to match the lift before installing them)
Can't answer that off of the top of my head. So.. I think so? My father-in-law wasn't much in the way of modification beyond what was strictly needed to increase utility (Thus the lights/bumpers/winch) so I doubt he touched the suspension at all in the last 10 years beyond picking her up to change the brake pads/rotors as needed.
Checked. Connected. Grabbed them and gave them a shake too, no movement.
Pushing down on the front end: She just kind of springs back up but it's hard to tell if there's much of a bouncing motion due to the jeep rolling a bit forward and backwards as well. I'm going to buy the OME kit. At this point it's just a matter of putting together the last bit of funding. In all reality it's probably a combination of shocks and springs just being worn after 10 years, no replacements and 110k miles, a good portion of them done with the bumper/winch mounted.
@Chris, going by your beginners guide to lifting post, given that I have an 06 Rubicon I shouldn't need a SYE, right? Just a new adjustable trackbar.
When your Jeep is sitting at a light, turn your wheel side to side and feel how much "play" is in it. That's how much wear is in all of your steering components. Could possibly be why your Jeep drives like a boat?
My Jeep's wheel doesn't have a lot of play in it, yet it drives like a boat (minus the 33" tires and 2" lift) because it's 10 feet long. Our Jeeps are much more easily affected by differences in the pavement and by the wind!
However, with yours being completely stock, and me not being an expert, i'd hope that the experts, I.E., @mrblaine, @Jerry Bransford, or @Chris will chime in!
There's actually no play in the steering wheel.
Thanks Chris. Looks like I'll be able to order that kit in the next week.
Can I get some recommendations on good adjustable trackbars?
Thanks for that breakdown @StG58, that's sound advice, I will heed.There is a solution. You can have the gratification of modding your TJ, but in bite size reasonably affordable pieces too.
Put a set of Duratrac's or KO2's on it (5) and use the stock wheels. When your shocks go bad, put a set of 0-2" Bilsteins on. Add a set of H&R springs as money allows for 1" to 1-1/2" of lift. Find a set of used TJ or XJ wheels that you like and swap them in. (I love the look of the Ravines, but there are a lot of choices out there.) You don't have to drop big money all at once to modify a TJ, you just have to research what you need and want, then spend wisely.
I know Rough Country doesn't generally get much love around here, but I opted to use their adjustable rear track bar in lieu of drilling out the rear track bar bracket for the OME relocation bracket included in the kit. Gave me adjustability, and is much more stout than the stock track bar:
http://www.morris4x4center.com/rear-forged-adjustable-track-bar-0-6in-rc-1075.html
My thoughts exactly. A big plus is it can be adjusted without unbolting either end.I did as well...and @ double the weight of the stock track bar, I'm satisfied it's an acceptable upgrade...$150 vs $400 for a steel rod with some threading made the choice pretty easy for me...
My thoughts exactly. A big plus is it can be adjusted without unbolting either end.![]()
