I'm going to be switching to a 4" lift and adding a ucf high clearance skid. Should I get the ssye or would I be fine with the normal sye?
Jb conversion SS sye.
healtech speedohealer.
tom woods driveshaft.
Looks like they have three choices, a 1310 and two 1350 choices. Any idea what the difference are? (Besides the price)
If you're ordering a custom driveshaft installing everything then measuring would be the most accurate. TW has about a 3 day turn around. Also, pay the extra $20 for the X spline.As far as the drive line goes does it make more sense to install everything than measure and buy. Or just buy it up front?
SSYE would probably be a better choice since it would give you more droop before binding.
Maybe @tworley will chime in since he runs a SSYE on a early model TJ. I believe he uses a speedo healer to run the speedo.
https://www.polyperformance.com/hea...wrangler-04-06-tj-98-01-cherokee-xj-shv4a-j01
