Do I need a winch cover?
I formed a cover out of kydex that only covers the rope and drum section, leaving the motor housing and gearbox exposed. It's really more just a rain and sun shield since there's enough opening that there's no way it could trap water and keep it from drying out.
I did the same thing using light gauge steel, painted to (almost) match the winch. I've had it on for a couple of years and it has held up quite well. Keeps sunlight off the synthetic line and doesn't trap moisture. I haven't had any issues with fading on the parts that are uncovered.
Man that looks sharp. Good job!
I have always had covers on my winches. the best to date is the bartact cover. This one is two years old in the picture and zero fading
Reactions: Apparition
No cover on mine. The synthetic rope is at least 6 years old and seems to be doing fine.
Reactions: J R
I read over and over how sensitive the synthetic rope is to UV damage.
Is there any real proof of the UV rays causing damage beyond the colour fading? I can’t see it be too sensitive when it is widely used in the marine industry and can’t imagine a harsher environment.
The stuff sits on docks and the decks of ships for years without anyone worrying about the sun.
Reactions: J R
Do you remove that cover when you use the winch?
I use one when I go wheeling to keep the mud off it. Makes cleaning it easier. Otherwise the Jeep is is my garage or driven on nice sunny days showing off the bumper jewelry
Reactions: matkal
I've been running a breathable canvas style cover in the PNW for the last 3 plus years and will pick up a new one soon as it's ready.
Could you please share where you got yours from?
I'm not worried about the rope. I'm worried about water getting into the winch internals and rusting it out in the winter time. Am I worrying unnecessarily here 🤔?
Mine has been daily driven and fully exposed for 7 years. And the winch itself is quite a bit older than that, living inside the bumper of a late 90s Land Rover. So far, so all I've done for repairs is rebuild the plug to the solenoids. A cover would have made no difference. I used it as recently as a month or two ago when I broke the axle shaft.
Reactions: psrivats
I had a neoprene cover on my Ramsey winch. The cover lasted about a year before it started to deteriorating and fell apart. I like Jerry's idea of a canvas cover.
