You can use the wj wheel in your tj. You need the complete steering wheel/air bag assembly.'01 owner is sad![]()
Looks great!
Once you have obtained these components, you need to install your air bag into the wj air bag cover.
The wj uses a two stage airbag which is not compatible with the tj.
If you attempt to do this, please be very careful.
