That's not an issue anymore unless you over flex it in the street position.If the Swayloc no longer breaks as it once did with ORO's earlier version, which is when I stopped paying attention to it, go for it if you need one.
The issue Jerry is referring to was limited to the first generation SwayLOC. The dates of the posts in the links to other jeep forums found in Post #1 suggest that the issue was remedied 14 years ago.
The first photo in Post #1 allows a comparison of the Antirock torsion bar and the SwayLOC torsion bar. Both neck down to 0.75" in diameter, they are nearly the same length, and it is my understanding that they are made from the same chromoly steel.
The air actuated version isn't great from what I've heard.
I was just told not to buy it from someone familiar with the product. I don't think I asked why at the time or I don't remember.What is it that you have heard about the air actuated version that isn't great?
Now I did manage to break the air cylinder once and neither Steve from ORO or myself could figure out how I managed to break it. But this was the only time I have had any issues with it. And I've had mud caked on the arms before and never had any locking or unlocking issues.
Interesting read. I am literally going out to install a AR right now.
I am running FOX LSC's (11") tuned by Mr. Coplin in the front. 12" LSC's in the rear. It is a trailer queen. I have not "seen" a swaylok on the trails I run, but lots of AR's. Am I going to be "happy"?
It should essentially be a linear rate, as it is just a cylinder. At very high deflection angles, the angles of the link to the arm may begin to have an effect on overall effective force applied, but the effect isn't likely noticeable at lower angles.I did a bunch of unpaved, light trail stuff today and have some observations. Is the torsion bar considered a progressive rate?
I
The AR should be angled up around 10-14*, not level.I spent about an hour removing the old swaybar and disco hardware. I managed to get the bushings in and the torsion bar installed and the arms "leveled". Looks like a winner.
Two things no one has mentioned that are big pros,
1) It looks cool
2) 2 stickers included
That's to keep it out of the tires when turning and to prevent the links from flipping the arm around at droop. If he's not having those issues, level is fine.
My bad, "even" would better choice of words. I have not put the links with the heims in yet. I read ahead on the instructions and noted your suggestion.
Level at the mid point of the suspension travel.
