@mrblaine, will you suggest the most likely places my TCase is leaking ATF? I’ve already checked the mating surfaces of both halves after cleaning everything up and they seem fine. All the ATF is on the drivers side, all the way from the front of the transmission back to the front output shaft., up high on the tub, covering the savvy transfer case cable, blowing over to the frame on the driver’s side. There’s none on top of the TCase, and the vent tube is secure and dry. All I know to check is the outer seal on the front output shaft. If that’s the problem, does a new seal require RTV on the outer and inner edges at install? Anything else to check, I’m tired of taking the case apart. This will be the third time. Argh...
