Bottom line, I do not think they are. As per above, they will accept an H4 compatible LED bulb, but that is not a legal set up. Also, since Jan the MOT checks were changed and it will be an MOT fail if spotted.How bright are the Hellas though? Is it comparable to LEDs?
Very conventional 80's style glass faced lamp unit ready for a H4 bulb and pilot light..think they will be in keeping with the TJ, not planning to do any dogging so no need for ulltra high power lights..!Tempted. What are they like?
Stuck there for a few days, now steaming past Crete to Athens, then Italy somewhere, then Newcastle ETA 12 April ish..My plan as well, just prefer the glass rather than polycarb and the more traditional look.
PS did you TJ have to come via Suez, was it delayed?
I’ve done the same for now: just installed them this afternoon.Stepped back from the edge and just went with Hella H4s
Hi, haven't got that far..awaiting my Jeep landing in the UK around 12th April then I can get my sticky paws on it!I’ve done the same for now: just installed them this afternoon.
One issue I had is the rubber 'boot' they come with to prevent moisture has a circular hole, and my stock H4 plug is sort of a square T shape. So I couldn’t fit the boot. What did you do?
You must be chewing your nails non stop at this point!Hi, haven't got that far..awaiting my Jeep landing in the UK around 12th April then I can get my sticky paws on it!
I think COVID has given me the patience of a saint...so for a decision to buy in principle it will be 5 months before I see the consequences of my decisionsYou must be chewing your nails non stop at this point!
Hi mate, I'm glad ive found this thread as I just installed some halo headlights, and realised that our Jeeps have a seperate bulb going into the bottom of the stock headlights, connected to a pos & neg spade terminal, im guessing this is the DRL/parking bulb? So my question is, the Americans show to wire the halos you connect the DRL cable to a add-a-fuse in the fuse box. So how would we go about it with our cables that are already wired for DRL? Should I just leave them disconnected and wire the DRL to the fuse box, or should I wire the cable on the headlight to the existing DRL cables? Id appreciate the help, thank you!I’ve got for the knockoff versions and I’m blown away by how good they are. They look like the real thing and cost a fraction of the price. I got mine from a website called Original Cafe Racer. Just make sure you get one with a DRL feature. Our UK Jeeps use the DRL as a parking light.
Okay brilliant thank you! So if I wire it to the fuse box, is it okay leave the side light wires empty ended and Just put electrical tape over them? Is it not bad to be supplying electric to them without them connected to anything or does it not matter? ThanksDepends what you want.
The side light wire will only be live when the headlights switch is set to sidelights (first click). If you want DRLs (on all the time when the engine is running - most modern cars do this) then you need to run a new wire as the Americans do. Up to you.
Perfect! Yeah I was actually just going to reinstall all the stock parts for MOT day, thrn plug everything back in afterwards just to save the chance of failing hahaYeah, you should be able to leave them taped up. It doesn't matter how you get the sidelights working, just as long as you do so you can pass your MOT.
Hi buddy, so I actually went ahead and took a shot in the dark and connected the original DRL lights to the Halo connector, and it works great, just comes on when I turn the stalk to the first click.Yeah, you should be able to leave them taped up. It doesn't matter how you get the sidelights working, just as long as you do so you can pass your MOT.
Thanks, I ended up going for these after all. Half the price and look like the JL headlights.
I'm hoping to spent about £100 not £400.
