Painted the roll bar covers back to black.
@GaTechTJ +1 on thisWould you mind sharing some info on this?
Sure. My roll bar covers and soundbar were faded almost to a purple look from 20 years of sun. Several others on this board have recommended painting them, so I decided I would give it a try.Would you mind sharing some info on this?
I’ll be darned, learn something new every daySure. My roll bar covers and soundbar were faded almost to a purple look from 20 years of sun. Several others on this board have recommended painting them, so I decided I would give it a try.
I removed the covers from all of the roll bars except the ones over the front doors. (These would require a torx wrench with a hole in the middle of it that I don't have.) You have to remove the top anchor point of the seatbelts to get the covers off.
I also removed the sound bar. It is 4 torx screws and a plug, so pretty simple.
I laid them out flat on plastic drop cloth's in my driveway and painted them with DupliColor Vinyl and Fabric paint. I let them dry for about 30 minutes and gave them a second coat.
For the bar covers over the front doors, I used the plastic drop cloth to cover everything but the bars, and gave them two coats as well. I put it all back together, and it looks much better than it did. There is a paint smell once I put the top back on, but I'm confident that will go away in a few days.
I purchased the paint at Advance Auto Parts. I had to go back for a second can, so you may want to start with two.
Hope this helps. Let me know if you have more questions.
I went with the advance adapters. It’s not cable but moves and simplified the linkage. I moved it into 4WD exactly twice during my ownership so a face acting linkage wasn’t super important and I could better spend the money elsewhere.This mod is coming up to the top of my list fairly quickly now...
Awesome. I hope you didn’t break the tube like I did.Finally got around to swapping out the rubber doughnuts on the valve cover for the crankcase vents, and the rubber doughnut seals for the windshield washer pumps on the washer reservoir.
Had to take the steel bracket of the reservoir and paint it since it was rusted.
Two minor tasks off one huge list of things to do!
I saw your ad. I knew you’d find something.Rattle canned my full doors that I traded half’s for.doesn’t match perfect but jeep is getting painted this summer
What tire/transmission combo?Finally started a very much needed re-gear. Got the front finished will start on the rear this coming weekend hopefully. 3.73 to 4.88
Did you wash them first?Sure. My roll bar covers and soundbar were faded almost to a purple look from 20 years of sun. Several others on this board have recommended painting them, so I decided I would give it a try.
No. I cut back the flange of the rubber doughnut about half way around so I could cock it back enough where the flange was missing to get a packing hook underneath it and pop the whole thing out.Awesome. I hope you didn’t break the tube like I did.
Yep Novak patent it,I did it first then everything I did since went so much easier, sye to body liftYou won't be disappointed. I went with the Novak version a while back and it was WELL worth the upgrade!
