So we should put the gasket back on then? Too easy. Will do it when I am home.When I change from hard top to soft top mine doesn’t sit correctly at first. After a couple of days in the sun it sits better.
Just popped out the airbag defeat and that gave access to the console area. Then just drilled a hole and mounted it. It connects to my radio head unit. It's actually an extension.Can you share pics & details of the USB charging port? I'm looking to put one in and am looking for options for placement, etc. How hard was it to install? Any advice? Thanks in advance!
Any bolts that get taken off get coated in anti seiz,which ones broke,can you get nuts behind them?I snapped three body mount bolts today while trying to add the savvy 1.25 inch body lift![]()
Your Falkens are beefier and badder than my BFG KO2sThey look well smaller than my 235/75/15 Falken At 3w,s, do you have any lift?
The two in the rear by the bumper. There should be enough room there to weld on a nut and back them out. But the one basically under the drivers side floor board snapped way up inside.Any bolts that get taken off get coated in anti seiz,which ones broke,can you get nuts behind them?
Started in on the TJ right of passage:
- New RMS
- New Cats
- New O2 sensors
- New oil pan & felpro gasket
- New felpro valve cover gasket
So far no broken bolts or bones!![]()
Installed magna flow exhaust. (I know i didn't go to my local shop for the $150 special.)
I did one similar, just a dual charger. I put in place of my cigarette lighter. Had to use a dremel tool to open the hole a little larger and wired it in. Easy peasy.Can you share pics & details of the USB charging port? I'm looking to put one in and am looking for options for placement, etc. How hard was it to install? Any advice? Thanks in advance!
Daaamn, 37's! Nice!
I believe the original end cap was mounted thereIn anticipation for my off-road trip on Saturday, I added some OEM rear recovery points.
I’m curious if there is something missing from my rear bumper area. In the last picture, it’s just open
