Looks like they extended it to the end of JuneSo is slick rock open now and if so when are we doing it?
I will see if I can get by this coming weekend. My neighbor said he heard it was open from someone else up thereLooks like they extended it to the end of June![]()
OKLooks like they extended it to the end of June![]()
September?I am up for doing it on Saturday Sept 26nd, anyone else![]()
Edit June 26thI am up for doing it on Saturday Sept 26nd, anyone else![]()
Wow, that's off the beaten path! Out of all the places you could have camped, why here?We got out up to Medicine Lake in Modoc county. We had a blast View attachment 257686View attachment 257687View attachment 257688View attachment 257689View attachment 257690View attachment 257691View attachment 257692View attachment 257693
Also I said Modoc County but it’s in Siskiyou Co. Not far off thoughWow, that's off the beaten path! Out of all the places you could have camped, why here?
Did you get your vibes dialed out?Also I said Modoc County but it’s in Siskiyou Co. Not far off though
I got a new TW front DS and all is well.Did you get your vibes dialed out?
If by away from the city you mean oakland then yes sir!Are you finally making a pilgrimage away from the city?
Tent city USAIf by away from the city you mean oakland then yes sir!
Yes I do sometimes run the factory soft top. Mine is an 05Norcal Jeepers, do any of you run a factory soft top, or a soft top that fits the factory bars, ie a replacement skin?
Next chance you get, would you check to see if your driver side rear side window has the zipper pull on the window, or if it's attached to the top? I'll tell you the story behind this once you find out.Yes I do sometimes run the factory soft top. Mine is an 05
I'm running the Bestop Replace-A-Top for OEM hardware.Norcal Jeepers, do any of you run a factory soft top, or a soft top that fits the factory bars, ie a replacement skin?
