kmas0n
I have no idea what I'm talking about
Damn! Where is that?
about a minute away from my house. Luckily things have calmed down.Damn! Where is that?
Wow... That is quite the picture.
I'll be mating the engine to a 6L80e transmission.
After reading your thread I've contacted zero gravity performance. They offer stand alone harnesses. I've been told with the gen 4 ecu it's plug and play. The only thing holding my back is thier harnesses have no provisions for any emissions controls. Although currently where I live we have no inspections, I worry that may change with the EPA unleashedGood transmission, but decide on how you're going to handle the electronics/wiring before you go and buy one.
The 3 link rear has been installed for about 6 years now. I love the way it performs. No hop on hill climbs, very predictable handling.I am very interested in the rear 3-link and how it has performed. When did you actually install the rear 3-link? You said you bought jeep in 2005 and this is how it sits in 2019, however, how long have you actually been running the 3-link?
It appears from the picture that you installed the upper at the stock driver side upper location, but attached it to the truss (which is attached to the passenger side at the stock upper location). Is there a reason you did not attach it to the center of the truss? I am assuming it is due to the fact that your frame side was actually mounted to the frame and you didn't want to add a truss to center the body side upper mount, but is there any other advantages/disadvantages to having the upper link centered? Seems like there would be a higher load on this upper link and it's attachments due to the offset.
Have you ever had any issues with cracking/breakage of the control arm brackets?
I’d like to hear how those engine mounts workout. They look to be above the factory mount from what I’ve seen also. I intend to try them unless I hear otherwise.I talked with Jim at Zero Gravity Performance today, he's going to send over a Stage 1 reman 6L80e 6 speed auto and a new stand-alone Engine/trans harness.
I think I've decided on a stage 1 cam from Texas Speed. Seems like there is plenty of support for their cams and I could get away with a mail-in tune. That should get me about 365 hp at the crank
I'm considering holly/hooker blackheart engine mounts because they mount to the existing 4.0 engine mounts after trimming off an inch or two. This appeals to me because the upper link of my 3 links comes within half an inch of the bottom of the mount at full stuff, so if it doesn't mess with the bottom of the mount, I may not have to mess with my links. From what I've read it doesn't mess with the steering shaft either. Anyone used these?
I'm planning to use Novak for the 6l80 -> np 231 adapter. From what I read on @toximus thread, they (atlas) recommend a 3:1 transfer case with the 6l80. The 2.73:1 of my NP231 will have to do. I already have an sye, but I might need the super short sye if my rear driveline gets any shorter... its already at its limit so we'll see
