thanks so much!Great build! I’m excited you’re 15 and doing all this. Looking awesome and gears and a locker! Woohoo!
It used to be common to suggest JUST adjustable lower CA’s. Then it was pointed out that you really need both.so I've been thinking of my build plan and I'm thinking I'll slightly change it, initially I was gonna get adj. upper and lower rear CA and after that a SS SYE, but I'm thinking in order to save money I'll start with just adj. uppers and then a SS SYE and then if I feel the need I'll get adj. lowers
how does that sound?
any other ideas?
hmm, I thought I had heard that adj uppers were more important for a SYEIt used to be common to suggest JUST adjustable lower CA’s. Then it was pointed out that you really need both.
That’s correct.hmm, I thought I had heard that adj uppers were more important for a SYE
maybe im wrong
That will work perfectly fine. I wouldn’t hesitate to go with that plan…so I've been thinking of my build plan and I'm thinking I'll slightly change it, initially I was gonna get adj. upper and lower rear CA and after that a SS SYE, but I'm thinking in order to save money I'll start with just adj. uppers and then a SS SYE and then if I feel the need I'll get adj. lowers
any other ideas?
NoiceThat will work perfectly fine. I wouldn’t hesitate to go with that plan…
Very cool, Kid. Great to see you wheelin’ it. Did you make it up and over that ledge?I finally did some Offroading! at a local Offroad park (local meaning 2 hour drive)
thanks to @MountaineerTom for the trail suggestions
I was amazed at what it could crawl over
it was TOTALLY worth all the work I had SO much fun
im hooked
Thanks! oh no it was straight down 6 or 7 feet on the other side.Very cool, Kid. Great to see you wheelin’ it. Did you make it up and over that ledge?
you hired a pussy, what did you expect?I got the gear oil changed today while my assistant slept on the job,
It sure is hard to find good help these days smh
and she even had the audacity to use my torque wrench as a pillow/blanket
Nice looking TJ. Mine is a 99' as well.here's a few glamor shots, im still waiting to get my gears swapped, once I have 4wd again I'll take it off-roading and (hopefully) get some cool pictures, and since I finally have my drivers permit I'll hopefully be driving down to uwharrie, which is a state park that has some 4x4 trails View attachment 269147View attachment 269146View attachment 269145
that's a nice looking TJ
