Do you need two air compressors?
I’ve got the ckma12 it’s half of the twin. It airs tires just fine. Give it time to cool once in a while if your worried about it.
I'd probably do a pair of the 1006 because they are cheap with the tank. Toss the tank and related tank bits and build a dual set up plumbed into a manifold or a tee.
If you compare the specs accurately, they are slightly better than the big ARB single.
They are frickin huge! I can't imagine a twin puma.
Reactions: Apparition
Alright seems like ARB mini is best for just lockers…
What’s everyone’s fav for tires? York? Twin ARB?
You wouldn't expect it, but I see more and more people - including many long-term wheelers who abide by the "buy once, cry once" mentality - recommending the Smittybilt portable.
https://www.amazon.com/dp/B004K25GMG/?tag=wranglerorg-20
The 2781 (not to be confused with the earlier 2780 model) has an impressive 5.65 cfm, which is only slightly lower than the 6.16 cfm of the ARB CKMTA12.
Reactions: kiwi
That little single-cylinder compressor comes nowhere near 5.65 CFM in actual use. If you find their more detailed specs you'll discover that 5.65 CFM is measured into 0 psi resistance... open air in other words. Our lungs can put out that much CFM into open air. Into a tire's back pressure, typically measured at 10 psi, would be likely around 1/3 that much.
Smittybilt plays games with their specifications including using that misleading type of CFM spec (into 0 psi backpressure). It is physically small enough that I knew it couldn't put out 5.65 CFM so I started digging. It took me a while to find the actual spec on that but I kept digging until I found it since you can tell by just looking at its small single cylinder design that it couldn't possibly put out that much CFM at a proper 10 psi (or so) resistance pressure like a tire has in it. I forget by now what it put out into back pressure but it was more like 2 CFM.
Edit: I just found this image posted in an old thread I was in, it's a reply from Smittybilt in their Transamerica HQ location in Compton CA.
I'd suggest a belt driven york. You'll have endless air, high cfm, and with its oil sump you won't need to add an external oiler though a coalescing filter wouldn't be a bad idea.
I have a sanden (comparable to york), but it involves a bit more maintenance
I loved my York in my previous TJ but when I priced York mounting brackets for my present '04 TJ ten years ago they were all at or close to $200. And they weren't easy to find either. That price was Just for the bracket. That's when I decided to put a CO2 tank together.
Reactions: kiwi
I have the stock pump for my front stock Dana 44 locker and a single ARB for airing up tires we have to fix on the trail. I trailer so no airing up and down. If I need more air I have a Viair RV kit in the truck toolbox. Will probably use the existing ARB for air lockers when I get the one tons built. Still have not decided to do ARB on both ends, or one auto one ARB.
Most of the off road park around here have a big compressor on site as well with an air station with multiple hoses.
Reactions: kiwi
I'm using the factory for lockers and have a now discontinued Warn PowerPlant but have yet to use it for airing up. When that pukes and I'm not able to find parts I'll have to reconsider adding a 2nd.
Any experience w/WPP?
