Do you have yours yet? Have not received mine and no word on when it will ship.
Nope, not yet.
The PCM is just not an issue of any longer with half a dozen companies reprograming good reliable used PCM's. My sources tell me these replacement PCM's are not from TJ's and the source of used ones is limitless.So, when shopping for a new to me TJ of the years 05 and 06, the easiest “fix” would be to just by a stick shift?
In fact if you find a 05/06 TJ/LJ that needs a PCM you might get a deal.
I’m sure glad I did not follow the advice of many who said ‘05-‘06 automatics should be dumped as quick as possible, even parted out.
Who here said that?I’m sure glad I did not follow the advice of many who said ‘05-‘06 automatics should be dumped as quick as possible, even parted out.
Who here said that?
Got mine Tuesday and installed Wednesday. My Jeep is an 05 LJR manual, one owner Jeep (wife and I). It would not run more than 5 minutes, died, bucked, threw random codes, gauges would come and go. Had factory pcm rebuilt twice by A1 Cardone through NAPA, did not fix problem. Head engineer at A1 Cardone said " not repairable".
The PCM I got from Mark fixed the problem! I got my Jeep back! Many thanks Mark.
My email address is [email protected]Mark,
I sent you an email to the yahoo address.
Is that a valid email address for you?
