What kind of scanner reads the 42RLE codes?
@Wranglerfix , I'm starting to get more frequent 1-2 hard shifts, but I have no codes when doing the key cycle 3 times and checking the odometer reading (it just says "done"), no codes (or pending codes) when using my OBD II and no Check Engine/Gauges lights on the dash, other than the check during initial start up. I don't know about trans codes because I don't know what to use to read them yet. It starts and runs fine as of now, other than the hard shift sometimes.
Can your PCM fix this issue considering I don't have all the codes and such?
I have an Actron CP9690. Another way to determine if it’s your PCM is to disconnect your battery for a bit. If after you reconnect, the hard shift problem goes away, then it is highly likely that the problem is your PCM. If that’s the case, the hard shifting will return soon. Good luck.
