Since my TT in April, I'm getting those nasty harmonic oscillating vibes under load about 65mph+. 4.0, 6-speed, 456 gears, JB SSSYE, Adams DC
I need some help with the CA's front and rear. I'm trying to get the angles right so I can decide if I need to go to the next step and clean or replace u-joints (how do you know if those are bad), and finally have one or both shafts balanced.
Front pinion = 8.5*
Front DS = 8.3*
Rear pinion = 17.0*
Rear DS = 17.1*
I tried to start with everything even, and I've adjusted the rear several times up and down and didn't change a thing. The front I adjusted this morning. Pinion was 9.3 and DS was 8.4 or so and the vibes were coming on at 62mph, so it's a little better now that they are closer to even. What adjustments would you make?
