I can live with 67%!
I would have loved to find one in Khaki Metallic, but I got a decent deal on this one and only a couple hours down the road. I'm actually kinda digging the white too. I've always tended towards dark vehicles, so this is a nice change of pace.
I love the look of white with black armor
I'm not aware of any that simply cover the holes, but these OEM style replacements are much sleeker than the ones you're currently running.
https://www.amazon.com/dp/B0013REXPW/?tag=wranglerorg-20
Same as above without the little extensions behind/at the base of the front flares.
https://www.amazon.com/dp/B001FAI9X4/?tag=wranglerorg-20
If you're going with a 3" spring, just add the extra inch and go 4". This sets you up for larger tires later and opens up more shock options. FWIW, shock options that actually work well with the suspension are surprisingly limited for 2 - 3 inch spring lifts. Plus, you can skip the BL now and add it later, when needed. That also simplifies worrying about transfer case shifter linkage.I had been leaning towards 2" of spring and 1.25" BL, but now I'm thinking I might just start with swapping the tired springs and spacers with some 3" springs, probably JKS.
Don’t forget to regear after installing the new tires. You’re going to hate 3.73s and the 42rle. Might as well install lockers too when you regear.
Wouldn’t the 4” require a TC drop and MML? Or one or the other to get the DS at the right angles? I am leaning towards 2.5-3” (probably 3”). Seems like a nice spot overall. Then if I want I can make mod’s later for TT without any loss of to what I’ve done.
That's the kind of slippery slope I'm nervous about! Once the diff gets opened up lockers will happen for sure.
It's handling the 31s like a champ, are 33s going to be that much different? That's part of what kept me looking at the 3" lift, a regear, SYE, DC, lockers just isn't in the budget right now. Hell, springs, shocks and tires hardly are!
What size of tires are on it? Not sure if the TJ needs to be updated the same as a JK, but if the tires are larger it may be messing up the shift points.
Its the high overdrive ratio in the 4 speed thats the problem. Can't put a bandaid on it like 5 and 8 speeds
Ah I gotcha. The factory must have known something was up, putting that overdrive cutout switch in there!
I think I'm still leaning towards a small lift and 31-33s. I'd rather keep it simple for now, if possible. But lockers are mucho enticing. And if I'm in there, it's a good time to regear anyway. Would 4.56 be a good choice for the time being and to keep my options open down the line?
