Why did you have to notch the spring perches to replace the shocks? I don’t know that I’ve seen/heard of this before. Was it due solely to the diameter of the Ranchos? I have 4” lift with RE shocks and mine aren’t notched. I’d go in the garage and look but I’m out of town.
Thanks, will definitely do. I just bought the Jeep last year and have not had a chance to wheel it yet. I want to say I remember mine being shaft up, cylinder down.With my 4" lift, at full extension my shock would hit the spring perch and dent it. This is pretty common - there are a few threads on this forum talking about having to trim the perch. Another common workaround is to flip the shock so the body is on top but when I researched it for my Ranchos they didn't recommend it. If you have a lift, you should check that yours are inverted or else jack up a rear wheel (slowly) and check for clearance.
DO IT, THEYRE AWESOME! Can’t tell you how many times someone has said “sweet Jeep, wait, what is that”. I smile and say “it’s an LJ”I'm afraid I will find a LJ that I cant pass up...would HAVE to be silver
That is one tall winch! On another note, Your bumper seems to sit low, especially those outer hoops. I would be concerned with approach/departure angle unless it’s just the angle the photo was taken at.Got the 8274 back from the polishing guy. He did an amazing job on it. I also called Warn's customer service and they sent me decals (for free) to match the ones from 1978! The non-aluminum parts (drum & brakes mostly) are going to be powder coated.
I have a new upper service kit, brake service kit, new bearings and bushings to do the rebuild. I also purchased a new motor (Warn's industrial line #70865) to replace the original which had worn out brushes. Apparently the new motor significantly ups the pulling capacity of this beast. One of the solenoids is dead so have a new contactor kit one the way which I may mount under the hood.
This is the mount I will be using. I'll need to do some trimming to make it fit but I think it will match the bumper nicely.
Interested in where you’re going to mount the amp. I’m looking into a micro amp also and want to mount it somewhere behind the glovebox.
