Prehaps a small lightbar like @jjvw.
Did he mount it to the bull bar?
Admittedly I just feel like re-purposing the factory fog light circuit / wiring with some sort of LED lighting. Of course something with a minimal footprint would be nice.
Yep, I agree, that's why I'm taking them off. It ruins the look for me on such a small bumper.
I think part of it though is the Savvy light mounts move the lights up to a higher position, which make them look a bit off being so tall. I may just forego lights completely, it's not like I need them. The KC LED headlights are bright enough as is.
I just drilled through the bumper to mount mine. You could sneak some small lights next to the winch under the hoop. Bars on the Savvy bumper are a little harder, because the fairlead mount does not mount evenly between the hooks. The winch guard would be the only place to mount on your bumper. I wanted to put two light bars on mine, but they would only fit on the passenger side.
Yep, something like this would do the trick. Square cubes do a look a bit off to me, especially on the front end. A small circular LED light like this might be nice and subtle.
Since they are cheap and sold via Prime, I'll likely order a set just to see what they look like. Worst comes to worse, returning them would be easy.
I suppose you could mount something under the bumper on the bottom side, but there goes that as soon as you hit something. I'll explore the little round lights that @zebra12 linked to above.
Like I said, I am just tempted to re-purpose the factory fog light circuit![]()
Has to be some of the worst lights I’ve seen lol. I’ve never understood this look. I’d delete it from your build thread hahaI’ll have to finish installing the synthetic winch rope and mounting the winch solenoid tomorrow.
Debating if these KC LED Daylighters look good or not though:
I used my factory fog circuit. Works fine for low power lights. You should be fine for most small aftermarket ones you can find.
Did you try contacting KC? They have pretty good customer service. Might be able to return/exchange em?I've seen them on some setups and they look pretty good, but I think it involves a full width bumper, or one that is much larger.
Either way, I posted them for sale, so hopefully someone wants some expensive ass lights for a good price![]()
I don’t have the original box, but I suppose I could try!
This doesn’t help today, but I’ve done this same thing enough times to start keeping the boxes for a short period after I open/install. I usually wait a trash cycle (which gives me anywhere from 7-14 days, depending on when I unbox).
Where do we stand on this build? When will we see photos of the 5" lift, 35's, and 4.88?
I saw your smiley lights sold, did you settle on replacements yet?
